The best sleep headphones 2026
If you're getting ready to embark on a summer vacation or work trip, there's an entire category of headphones and earbuds that warrants your attention: sleep headphones. These products can simultaneously block out unwanted sounds and play your favorite music, podcasts, or white noise to ensure you get a perfect night sleep, whether you're in your bed or on a flight overseas.
If you've ever tried wearing some of the best wireless earbuds to bed, you probably know that regular earbuds aren't that comfortable for sleep. That's why sleep earbuds, sleep headbands, and sleep over-ears exist — they are designed specifically for comfort in all sleeping positions. Most sleep earbuds are characterized by a low-profile design that rests within your ear canal, while open earbuds, sleep headbands, and sleep over-ears avoid it altogether.
There are a bunch of different reasons for why you might want to wear a pair of earbuds or headphones to sleep. Maybe you sleep with someone who snores or live next to a noisy train station. While traveling, you might want to block out airplane turbulence or car noise to catch some sleep. The Soundcore Sleep A30 are the best sleep headphones we've tested, and these are your quality options.
How to choose one of the best sleep headphones in 2026
The Anker Soundcore Sleep A30 earbuds.
(Image credit: Brady Snyder / Android Central)
Not everyone has the same sleeping preferences, so not everyone will like the same sleep earbuds. The closest thing to a one-size-fits-all solution are the Anker Soundcore Sleep A30, which are affordable and comfortable sleepbuds aimed to fit in a variety of sleeping styles. They have neat tech inside, including an MEMS electrical sensor to track your sleep and create a quality score. With these earbuds, you may be able to ditch your smartwatch or fitness band.
The Sleep A30 earbuds come with a pre-loaded sleep sound library, but also work as standard Bluetooth earbuds. In sleep mode, you can get up to 14 hours of battery life on a single charge — that's more than enough for even the longest snooze sessions. At $190, the Anker Soundcore Sleep A30 strike a nice balance between premium features and affordability. Compared to the Sleep A20, the A30 add active noise-canceling for the first time.
Those on a budget might prefer the Anker Soundcore Sleep A20, the older model that's available for a $30 discount, sometimes more. It still offers solid battery life and features aimed to help you get a good night's sleep.
On the other end of the spectrum, there are the Ozlo Sleepbuds, which cost a lump sum of $350. For that, you get a premium set of earbuds and a companion charging case with a bunch of sensors and features. The earbuds include a sleep-detecting accelerometer, and the case offers a tap detection, ambient noise detection, an ambient temperature sensor, and an ambient light sensor. All these factors can be used to determine your quality of sleep, and a built-in alarm helps you wake up.
Plus, you get Bluetooth Low Energy support for ultra-low power draw and Android features like Auracast. Though, for many, the price is too high with limited feature advantages compared to the Sleep A20.
Nothing Ear (open)
(Image credit: Tshaka Armstrong)
Having anything in your ear can be uncomfortable for some sleepers. If that sounds like you, we have some outside-the-box picks for favorable sleeping environments. For starters, you can consider the SleepPhones — a headband that covers your eyes and sports inbuilt speakers for media playback outside your ear canal.
There are also the Nothing Ear Open, which are open-ear buds that remain outside your ear canal. They're bulkier than the other in-ear options, but can be used in a variety of situations, like fitness and everyday wear. Side sleepers should pass on the Nothing Ear Open, but they're an excellent option for people who sleep on their back or stomach. Side sleepers can also opt to only wear one earbuds for a more relaxing experience.
A pair of over-ear headphones can come in handy for sleeping in upright positions, making them an amazing choice for airplane trips, train rides, and long road trips. For that, the Sonos Ace are impossible to beat. They feature comfortable memory foam and vegan leather materials for comfortability and aren't too heavy. Plus, you get active noise-canceling — most in-ear sleepbuds only use passive sound isolation.
With USB-C and a 30-hour battery life with ANC active, the Sonos Ace can be your travel companion every step of the way. They're a great pair of everyday headphones, too.
When choosing a pair of sleep headphones, you should consider whether you're willing to spend money on a dedicated care of night earbuds. If you aren't, the Nothing Ear Open or Sonos Ace may be a more value-oriented option, as they can be used all day and all night. Regardless, you can't go wrong with any of the headphones or earbuds on this list for sleep.
A note about safety
Headphones, like most of the gadgets in our lives, are usually powered by lithium batteries. The batteries used are designed to be safe over their lifetime, but issues do arise that can turn one into a dangerous situation.
Lithium batteries all have an acceptable failure rate, and part of that is them catching fire or exploding. This almost never happens, but it has happened. You want to do everything you can to make sure it never happens to you.
Pay attention to the state of the batteries in your earbuds, especially the ones you'll be using at night while you're asleep. If anything changes, like the charging rate or the battery life dramatically lowers, stop using them. Visually inspect things from time to time, too. Look for any leakage or swelling and only use headphones with batteries you know are good. Especially at night in your bed.
Brady Snyder
Contributor
Brady is a former contributor for Android Central, who wrote for the site from 2023 to 2026. With a focus on news, phones, and audio, he spent years reporting and commenting on all things related to consumer technology.
Brady reviewed Apple, Google, Samsung, and Motorola phones for Android Central, and attended industry-wide events like IFA and MWC on behalf of the publication. He holds a bachelor's degree in journalism from St. John's University.
His work has been published in XDA, Android Police, Android Authority, MakeUseOf, and SoundGuys, among other sites. When he isn't experimenting with the latest tech, you can find Brady running or watching Big East basketball.
With contributions from
